Questions about the LQ4 motor.
First being, will pre-04 LQ4 motors bolt up to the 4L60E? I heard once from someone that they wont due to a spacer in the flywheel/crank.
Secondly, What is the deal with the LQ4 heads? Are they LS1 heads? If not then are they any better than LS1 heads? I believe their Compression is lower than LS1's so they're probably not the same heads, that or the pistons arn't the same. Why are they rated 25 HP less than the LS1 when its supposedly the same motor only in cast iron?
Third, What would be a budget complete N/A build for 450 RWHP out of a LQ4? What kind of heads / cam would you recommend?
#1: There isn't a spacer, but the crank sealing lip is a bigger/wider than the '04 up (For some reason i thought it was '03 up)
#2: You are right, compression, compression, compression. You can mill the heads to get that extra oomph that lacks the LS
#3: Not to sure as i have no real world experience with them. However I was researching LQ's before i found my LS1. With that being said, I read that the 5.3 head flow 300+/CFM in stock form and make for excellent stock heads to throw onto the LQ4. As for a cam, you'll have to decide what else you want from it...
-Someone correct me if I am wrong...
-Justin
Ill take a stab at this:
-Justin
-Justin
What are the specs between the LS1 and LQ4 heads? Will LS3 heads make for a good replacement on the LQ4 followed with a mild cam?
LS3 heads would be a great option, but would need milled considerably to get the compression up and you'd still be at a loss due to the dished pistons. Keep in mind that the LS3 heads will require different rocker arms, and intake manifold so this may not be as budget minded as you might want. When I build mine I swapped out the pistons for some Mahle flat-tops to get compression up and used the LS1 heads I had laying around. With the TSP 233/239 cam I put 420hp down to the wheels everthing else being pretty stock.
Actually I have an 02 LQ4 in my Camaro and my 4L60 bolted right up, only some of the engines had a larger lip on the back of the crankshaft. This is just one of the things to look for when you go looking at these engines. The 6.0 heads (casting 317 iirc) have larger combustion chambers then LS1 heads (casting 241,853) but the LQ4 also has dished pistons being the only difference between an LQ9 (flat-top pistons) and LQ4.
The 317 heads on the LQ4 and LQ9 are based off the LS6 head with larger combustion chambers. They flow pretty much identical to the LS6 heads which are a step above the LS1 heads. Because of their larger chambers they're one of the best picks for forced induction applications.
I see. LS1 Heads it will be in that case. Did you change the valve springs for that cam or are your heads completely stock? The only problem is the LQ4's I'm looking at are all on Ebay so there's no way I would be able to tell if they would have the larger lip or not, in fact I wouldn't even know exactly what the larger lip looks like as I've never seen the smaller lip lol. I still think an LQ4 would be a much better choice than an LS1 due to the slightly cheaper price and larger displacement. Where did you get your LQ4 block and how did you know the difference in the lip size?
I think you're on the right track, LS1s are a great engine but I'd go the iron 6.0 route again. Besides if you use the stock bottom end in a LQ4 you'll easily get a couple rebuilds out of an iron block, just not the case with an LS1 you'd be lucky to get one.
400, 4l60e, 53, bolt, compression, crank, heads, lq4, ls6, motors, number, procharger, replacement, specs, throw, transmission
