is this fuel pump kit good?
Old 10-21-2009, 12:25 PM
rtpassini's Avatar
Default is this fuel pump kit good?
http://cgi.ebay.com/ebaymotors/TPI-L...Q5fAccessories
it will be for an lq4 in my 1980 T/A
Old 10-21-2009, 02:31 PM
SpecV44's Avatar
seems like it would work, i dont like that it is a no-name pump, and the inlet/outlet are 5/16 instead of 3/8 but to each their own. Personally I would find a 58psi in tank, or go with a boost-a-pump kit like the one below. If you look around you can find summit brand and whatnot.
http://www.summitracing.com/parts/CCA-82020/
Old 10-21-2009, 02:35 PM
SpecV44's Avatar
After looking, personally I would go with THIS kit. It is a reputable brand, from a reputable company. You will need a return/self regulating fuel rail (If you keep the stock truck intake with 2 fuel lines then u are good), or a 2000 Corvette fuel filter if you are running a 1 fuel line intake.
Old 10-21-2009, 05:04 PM
rtpassini's Avatar
thanks for the help!
can I add an adjustable fpr before the rail?
Old 10-21-2009, 10:28 PM
rtpassini's Avatar
is the zex brand any different/better than the carter?
I dont mind spending a few extra bucks if zex will work better.
