LS1 rebuild kit
the kit that mrmahone listed from summit is a good kit, however I will go with one of our sponsors like Texas Speed since the pistons on that kit are standard bore. Unless you have a brand new block you will need to hone your cylinders and will require oversize bore pistons. I myself just purchase a 3.905 piston from JE but I think you can go with a 3.903 but I am not sure who makes them. it will also be good if you can tell us what you are building i.e. a stock rebuild or a performance rebuild? you can rebuild your engine using your stock rods and crank (you will need new rod bolts) and have a nice 347 cid block. any way you decide to go make sure you do your research so you don't end up wasting time and money.
