Koni on Lower perch affect on handling and ride?
Old 10-21-2009, 09:41 PM
xRelapse13's Avatar
Default Koni on Lower perch affect on handling and ride?
How would lowering my konis to the lower perch affect ride and handling? Car also has strano springs, sways and watts.
Old 10-21-2009, 10:50 PM
jmilz28's Avatar
Do NOT use the lower perch with lowering springs. Sam will tell you this.
Old 10-22-2009, 10:49 AM
LS1TECH Sponsor
Sam Strano's Avatar
I don't recommend the lower perch in conjunction with lowering springs. Can't stop you if you want to do it, but you are left with very little working travel. As such the ride will firm up a good deal. It's a free country, the only time I'm ok with it is on cars that sit high in the front (say had a good bit of weight removed).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 10-22-2009, 10:22 PM
xRelapse13's Avatar
looks like i'm going to be staying at the way it is. I'm not trying to sacrifice ride and handling.
Quick Reply: Koni on Lower perch affect on handling and ride?
