Plug indexing???
might be a hassle but like anything matching the cylinder combustion character will help the engine to run better. The more even the cylinders are matched the better its going to perform. From timing to fuel the better the cylinder are alike the better the computer can demand power from the engine.
I always do it. Why make mods to a car if you're not gonna follow through w/ every aspect? Also, why would someone not want the most effecient combustion possible? If you decide to do it, index a little more toward the intake valve side.
I do it, usually takes 16 plugs to get 8 that match up for me but the last time I lucked out and had 8 that were right on. I only do this because I grew up this way and I do believe in reading plugs. I think I get a better read, I also like to make the cylinders as even as possible. As long as the ground is up and not facing the piston that is what is important to me.
I just read a short experiment http://dodgeram.org/tech/gas/spark_p...0_indexing.htm that says the ground should face away from the quench pad. It seems like, it would be a cheap improvement...even if it was only 5hp.
The only reason people usually indexed plugs is b/c the dome on the piston would push the electrode shut.
We have to do this on our 565 b/c the clearance is so tight between the piston dome and cylinder head.
Is it worth doing? Sure, if you have a few hours/$$$ to waste for a couple boxes of plugs or indexing washers to get .25 HP.
Bottom line, I would do it unless your pushing 700+HP.
My opinion.
My opinion.
Buy indexing washers from a sponsor like Summit Racing. No need to buy extra plugs. The washers will allow you to get any plug in the correct rotation, facing the desired area. You want the elbow side (back side) of the ground strap to face away from the combustion chamber. The open area between the electrode & ground strap face the combustion chamber; prefferably a little more toward the intake valve side.
