Lca Relocation Brackets On Stock
Howdy yall i am going to get some Aftermarket LCA and a panhard bar.I have stock ride hight.Are the relocation brackets a good idea?What will be better?WIll i still get a traction gain if i mount Aftermarket LCA on the stock mounting points?Also will relocationg the LCA Effect cornering?Also wich is better bolt on or weld on?
THANK YOU AND HAPPY HOLIDAYS YALL!!!
Mounting an aftermarket LCA in the stock mounts will usually reduce wheel hop which is caused by flexing of the flimsy stock arms and the give in the factory rubber bushings. Relocation brackets may give additional traction, it seems to be dependent on your choice of tires, your horsepower level, the track surface and many other things. All I can say is try it.
