torque to yield head bolts?
Old 10-24-2009, 02:54 PM
captainstalin`'s Avatar
Default torque to yield head bolts?
are the stock head bolts on an ls1 torque to yield? the gm bolts on summit say torque to yield. regardless i need to buy new head bolts, i was just wondering if anyone else would be able to use them
Old 10-24-2009, 05:12 PM
conan's Avatar
Yes GM head bolts are torque to yeild, one time use.
Old 10-26-2009, 10:26 AM
JASON 77's Avatar
one time use, and when a friend did his the torque numbers were all over the place. would just buy a set of ARP and b done. they r reusable.
Old 10-26-2009, 10:49 AM
H'ville TA's Avatar
Just curious - you say ARP. Can you still pull the heads on a motor that has APR studs installed while the motor is still in the car? Is there enough room to clear the studs?
Old 10-26-2009, 11:21 AM
conan's Avatar
I have ARP studs and I have removed and reinstalled the heads with the moter in the car.
Old 10-26-2009, 11:33 AM
00Silv4.8's Avatar
I reused head bolts on my 6.0, I didnt see a real big problem with it but I would recommend replacing them
Old 10-26-2009, 11:36 AM
bigboykilroy's Avatar
You didnt reuse your stock 6.0 head bolts did you?
Old 10-26-2009, 11:38 AM
BIG_MIKE2005's Avatar
Yep, as stated they are in fact TTY bolts. Some people have re-used them but it's not suggested. You also have 2 options with ARP, studs or bolts. If you dont wanna mess with the studs, just buy the bolts. But yes, heads can be removed with studs installed.
Old 10-26-2009, 11:45 AM
DO NOT REUSE your old head bolts for any reason the GM ones are one time use only.
Just buy a set of APR studs or ARP bolts and call it a day.
Old 10-26-2009, 11:52 AM
00Silv4.8's Avatar
I did and never had any problems
Old 10-26-2009, 11:57 AM
That is a VERY VERY bad idea. You may snap a bolt the next time you go to take the heads off. You also dont have the right torque on you heads currently because of the bolt stretch.
Old 10-26-2009, 12:27 PM
H'ville TA's Avatar
DON'T reuse your factory headbolts like bigboykilroy said. At the very less, purchase a new factory head bolt kit (one kit per head) from your GM dealer or summit racing. They run about $25 per set. part number GM - 12498545.
Old 10-26-2009, 12:31 PM
BAD2000TA's Avatar
Yeah, really!! It's too cheap not to use new bolts!!! And I thought I was cheap!!!
Old 10-26-2009, 12:36 PM
1SLwLS1's Avatar
wow, wish I would known that you could pull the heads in car with studs, thats what I would of done
Old 10-27-2009, 08:28 PM
i was just looking to see if i could give away the bolts im not using. looks like theyll just be utilized in the cracked block engine table
Old 05-10-2011, 03:29 PM
lugby's Avatar
http://www.enginebuildermag.com/Arti...rod_bolts.aspx
Old 05-12-2011, 12:59 PM
BAD2000TA's Avatar
And that was helpful how???? The thread was regarding HEAD BOLTS, not connecting rod bolts.
Plus, nice resurrection of an old thread for no good reason....derr.....
Old 05-12-2011, 01:08 PM
ShortChevy's Avatar
Lol, derr.... made me laugh, and the link is wrong. Sure TTY bolts can be reused soemtimes. Get out a bolt stretch gauge and check them. The link says only replace if damaged.
Quick Reply: torque to yield head bolts?
