truck coil/truck TB fitment issues on Fbody setup, need some input
I forgot that I had the truck coils and that I would run into problems mounting them with Fbody fuel rails, so I'm going to have to figure something out. I know I heard that you can bend the fuel rails a little to make the truck coils fit, but that can't be a very good solution, can it? And I'm not even sure that it would work with my setup anyways because I'm using some Russell compression fittings on the fuel rail, so they stick out a little further than stock fuel lines anyways. Am I going to have to get Fbody coils? And another question, will Fbody coils fit on the truck coil brackets, or do I need to get the Fbody brackets AND coils?
You can see the bolt holes are a little more than 1" off from where they should be to mount the coil bracket. I'm guessing I'm going to HAVE to get car coils?
And this question I have regards anyone using a truck throttle body. Isn't this outlet on the TB supposed to be for the PCV system or something like that? If so, there's no way I can get the rubber hose on the nipple because the front bolt for the throttle cable bracket is in the way. Did anyone else experience this issue? What did you do about it?
I agree its not the pretiest thing in the world but if you do it to both sides its more apealing to the eyes that way then with just one side sunk down. alo if you could get some information on the inner diameter on the tb and it is indeed 85mm like im thinking that be something id really want to swap to. good luck with however you decide to do the coils
I will try to figure out how to measure the inner diameter for you and post it up. I am also thinking about just trying to bend the fuel rail a bit to fit the truck coils because I was just informed that fbody coils hit the HVAC box on the passenger side in a 3rd gen swap.
just bend the fuel rail line slightly. and also u can clock the pcv tube on tb. take some pliers to it and twist with care. the tube is steel and pressed to the alum body. or remove the tube and plug or cut down for clearance.
i had my fuel rail bent for yrs. and have done to various cars running truck coil packs and brackets. just take the time to do correct.
