Help me select a set of budget heads for goal??
See sig, Running stock 241's with patriot shimmed dual gold valve springs, and trunion upgrade on rockers.
Im not trying to spend a lot of cash or drop Compression any more. What would be a step up that flows good with FI, and I can still use all other parts. The stockers now will be a restrictive hold back as to what the engine and turbo are capable of.
Looking to buy a set bare, that are polished and flow better then 241's, cheap!!
what compression are you at now? if you don't want to gain compression then 243's are out. if you don't want to lose compression then stock 317's are out as well. a set of 317's with a nice VJ, some bowl work, and a mill to keep compession the same would be a nice improvement over a set of 241's. this would be a nice budget upgrade. with the price of the castings and the work you would be around $800
Maybe pick up a used set just not sure what to go for on the street. Im at 9.6:1 at the moment. Down the road when this is not a DD I will put 317's on and be around 8.5:1 and throw more boost. But for the street and drivability the 9.6:1 I like.. But these stock heads are costing me 60+hp in the setup if not more. Just everyone I talk to says dont waste your money in the 241's.. and around $800 would be great. Could I not mill a set of 317's and still benefit?
LS1Tech Premium Sponsor
The PRC Stage 1 LS6 heads are a great buy for a budget. At right at 1k you'll have a great flowing set of heads for the $$$. We also offer cnc ported 241 stage 1.5 heads for $700 with stock springs. This combo moves high 280s cfm using the stock 241 chamber. It's nowhere near as good air flow as the LS6 heads, but for very little $$$ it's a good option.
http://www.texas-speed.com/shop/item...d=649&catid=20
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Can I buy them bare and use my springs, shims, valves, rockers etc? Really dont need the springs. This would be a good upgrade for FI? Thanks for all the other parts, I got all my stuff thru you..
Also what would the LS6's do as far as my compression now? Also my cam is .595 lift so the LS6 put me close to 300CFM am I reading this correct?
