Monsoon experts ( inside)
Please help if you can.
started out with crackling in my front seakers.
replaced them with Alpines, still crackled.
bought another factory monsoon amp, still crackles.
Where do i go from here!!!?
Please help, i want to keep the factory stereo.
what next? TIA..............
Originally Posted by Rogue Leader
is the crackling at all volumes??
However when i increase the volume they ( now both fronts) crackle like crazy!?
It is worse on the pass side. but now it seems to be moving to the drivers side, only not as bad.? What can i do?
TIA........
I had a similar problem with my EQ in my truck. I ended up buying a new one. It sounds like the POT on the volume control is worn out. This is just a guess. Try hooking up another radio temporarily to see if this is the problem! Good luck!
I have the same problem with rear seat SUBS
I have the same problem with rear seat SUBS....
I replaced the SUB...... and the Monsoon Amp. Still have the same annoying rattle in the SUB......
I'm thinking it has to be the HU..... Any more ideas?
