Torquer V2 cam with stock 241 heads
Im going to be running the torquer V2 cam with my stocl LS1 heads. I was wondering if anyone else is running this cam with stock heads and if they like it. Also what RWHP are you putting down? When i do the cam im going to put roller rockers on and im also doing Pacesetter LT at the same time i do the install of the cam.
Any info would be appreciated.
Thanks
Thanks
thanks yup stock 241's i dont dd my car but i could its just too loud for me, a trans am has too many rattles and clanks to be a dd lol. only thing is a little bit of a pain it i get a little surge down low so instead of say rolling to a stop sign and leaving it in first i have to push the clutch in but thats expected
I have a 99 with stock 853 heads and it made 392/362 with cats. Been running 11.8s but looking for 11.5s this winter due to some changes I've made to the car. As far a DD, absolutely. Your tuner will need to be spot on however with pretty much any cam setup, the only issues I have are with warm start ups and if you are at an idle then switch on the AC it wants to surge a little but if you are driving then turn on the AC and stop you have no surge problems. As far as the warm start up goes it's not bad but the car will surge about 3 times before it catches it's idle. Great cam in my opinion, several members running 10s na with this cam. GL
All the surgeing sounds like it would make it a bad daily driver. IKm not evcen running the a/c. The compressor is on the car so i could but i just took the belt off. See i was originally going to do the 228R cam which all i hear is good things but the guy at TSP said the Torquer V2 will make slightly more HP and still be DD.
I dont have the torquer v2 cam but my lmr cam is identical to the specs on that cam. I just dynoed my car this past weekend 02 zo6 long tubes, catless x pipe, stock zo6 ti, same cam, ported fast 92 it did 437hp 397tq.
you guys that made over 400rwhp with stock heads and v2 cam...how high was the engine revved to make that, asking cause i made 400 flat@6200 with v2 cam and ported 5.3L heads with all the bolts-on's...trying to figure out if something is wrong/lose maybe a leak somewhere...manual car
what intake you using?? i have the tv2 cam with tsp stage 2.5 ls6 heads and bbk intake with full exhaust and bolt ons and i only put down 410hp/372tq and i'm leaning towards the intake holding me back
