stock studs on weld rims???
is it bad to run the stock studs w/ welds? right now i have 15x8 draglites and 5/16 spacer on the rear. will this be able to handle launches w/o breaking something? btw my car is a4 w/2.73 and stock stall with bolt ons. i havnt taken it to the track yet w/ this setup and it would be nice to know if im setting myself up for problems.
btw wasnt sure to post this here or in the wheel and tire section so if it needs to be moved go ahead
im eventually going to get the correct studs. its just so tempting to take it to the track w/ these wheels cuz ive never had skinnies and DR's before. thanks for the quick reply
i run them with a spacer and ive been 1.53 60s no problems run them weekly actually...just re-torque them after each run after a few runs you will be ok, mine seems not to back off anymore after a few runs
Internet Mechanic
A proper tech guy will say it needs to protrude 1/4 of an inch (or half, as I do not have the book infront of me) past the lug nut.
Stock studs do not have the strength to handle the sheer and will either bend or break. Its borrowed time. Like said, its cheap to upgrade, I will be getting properly lengthed studs for my new rims, when they show up.
Internet Mechanic
You will have to look at the rule book as almost 98% of tracks follow, unfortunately individual choice can be the diff between caring and not caring about things like studs. There is a rule about needing metal valve stems and I think it is ET related but again. I gotta find my book.
Due to ease of inspections most if not all tech guys want to see the stud and not have the owner take off to show it has a longer stud, As some wheels may have all the threads, some are held on with 2 and 1/2 which happens and is dangerous and ultimately can lead to a costly breakage of your car and a waste of my time and other drivers.
I ran the stockers for a while before I upgraded to ARP's with no problems. I doubt you will have an issue with a bolt on car, but you should upgrade them as soon as you can. You can use your stock lugs and wheels with the longer studs, but won't be able to use the plastic lug covers.
well i will see how it goes as far as passing tech. i just want to get a few runs in. i will be ordering longer studs and not luanching it anymore until those are installed. thanks for the comments guys. here is the thread w/ pics of them on my car
https://ls1tech.com/forums/appearanc...draglites.html
