Help Choosing Turbo
Old 10-26-2009, 05:21 PM
1998TA__1991RS's Avatar
Default Help Choosing Turbo
i need some help with my setup, im going to be running a foged 347 (stock crank) at around 9.0:1 compression. my goal is for around 850-900 rwhp and still be streetable, this will be a truck manifold kit also. im looking at a borg s475, or a pt88, would this be achievable on the s475? any other good choices without droping alot of cash on a turbo?
Old 10-26-2009, 05:34 PM
also this is mainly an 1/8th mile car, it may see the 1/4 a couple times a year, im shooting for high 5's with the setup
Old 10-26-2009, 10:44 PM
Orangemagic's Avatar
I would also like to know
Old 10-27-2009, 12:11 AM
ScorpionT's Avatar
What kind of setup do you have?
Old 10-27-2009, 01:21 AM
devilssled's Avatar
it depends on how fast u want to get full boost? i would choose a devided turbo with a lower A/R so it will spool fast as hell. mp76 or the new mp80 thats comming out
Old 10-27-2009, 04:35 PM
well being an 1/8th mile car i would like it to get into boost pretty quick, would high 5's be achievable with a 76mm?
Old 10-27-2009, 04:47 PM
cablebandit's Avatar
i would think a s480 would work well ...ask Jose at Forced Inductions
Old 10-27-2009, 07:22 PM
i pm'd jose last night, still waiting to hear back
where can i find some info on this mp80?
Old 10-27-2009, 09:29 PM
LS1TECH Sponsor
DrTurbo's Avatar
You will need at least a 80mm to 88mm for the level of power and speed you are wanting.
Old 10-27-2009, 10:02 PM
so i guess its 80-88 then, im looking out for a good used one, how much would a new 80mm run?
Old 10-28-2009, 01:21 AM
LSX Truck's Avatar
streetable as in power off the line? or just driving around town. I'd go for a T76 with the ability to up the boost when needed
Old 10-28-2009, 09:59 AM
Josh@KY-Turbo's Avatar
There is a New T4 based 91mm Unit to consider.
Old 10-28-2009, 10:18 AM
LS1TECH Sponsor
DrTurbo's Avatar
Yeah forgot about that one as well.
Old 10-28-2009, 10:34 AM
4SFEDZ's Avatar
im runnin a s475 on my lt1 and its gone 6.20@112 2nd time out on pump gas. so i think with good flowing heads and a good spec'ed cam a s475 will get you there but itd be maxed out! it would prolly be pretty laggy on the street tho!
Old 10-28-2009, 10:54 AM
LS1TECH Sponsor
DrTurbo's Avatar
You prefer to run a turbo around 80% most of the time if you can. 100% will mean rebuild and lots of HOT air from the discharge.
Old 10-28-2009, 05:47 PM
streetable as in able to drive it around or to work if i wanted
can i get more info please on this 91mm t4?
Old 10-29-2009, 05:12 PM
LS1TECH Sponsor
DrTurbo's Avatar
HP series 91mm comp wheel with mid-frame package. T4 turbine housing.
Old 11-02-2009, 05:02 PM
any more suggestions? what size wastegates should i be looking at?
Quick Reply: Help Choosing Turbo
