Stereo & Electronics - want to change my stock speakers..
z28_n_tx
10-26-2009, 08:51 PM
looking to upgrade my stock speakers.not looking for a bad ass system just an up grade. keep im mind ill keep my stock headunit for the time being.. what speakers should i look for??? and would an amp be necesary??
thanks for any help
Nauty99SS
10-26-2009, 09:01 PM
http://www.keeaudio.com/
check here
z28_n_tx
10-26-2009, 09:56 PM
check here
are the packages listed on here just for replacement of the stock speakers?? or are they somewhat of a better up grade??
pentavolvo
10-26-2009, 09:57 PM
faq and search, this is asked almost daily
7camaro7
10-26-2009, 10:18 PM
I'd also like to know. Will the speakers handle full bass from the factory 500w monsoon without blowing?
I didn't see faq on that site either
stan6898
10-27-2009, 01:34 AM
the speakers are a definite upgrade from the stock subs in the sail panels. The bazooka's (the best choice for subs IMO) will easily handle the full bass of the factory amp. The Bazooka's are noticeably beefier and sound much better. They will fit in the factory hole without any need for modification, other than new holes need to be drilled in to secure them. I had Bazooka's in mine for about a week and they sounded great. I removed them and ended up going with a sub in the trunk and placing full-range coaxials in the sail panels instead of the subs.
ls1ya
10-27-2009, 01:46 AM
sorry guys i got this one, you need infinity kappas. excellent speakers. i have the 6 1/2's in the kick panels up front, 5x7's in the sail and 6x9's in the rear hatch. and 2 12'' kickers in the trunk. but really no one needs this much it just looks good. you go with the 6 1/2's in the kick panels and 5x7's in the sail with a 600 watt four channel and you'll think your at a live concert. super crisp.
bmnicolosi
10-27-2009, 03:19 PM
Why would you put 5x7's in the sails? Def do not do that, put either a 6.5 or 7. And 6x9's in the back is just ghetto, sorry.
PIZDETS
10-27-2009, 03:21 PM
Another vote for Kee, I upgraded a month ago to a stock replacement system. Loving it
z28_n_tx
10-27-2009, 10:08 PM
soo 6.5 front middle and back?? and no amp. needed??
MotleyCrue
10-29-2009, 11:16 AM
Looking to upgrade "rear seat side panel" SPEAKERS
The factory ones cant handle the bass from my Head unit. (Pioneer Premier DEH-P980BT)
The one is ready to blow. Especially when I put it on BBE or LOUD setting.
I know they are 6.5's. They just put out the mid sounds, correct?
Any recommendations? Something that can handle bass.
http://www.crutchfield.com/S-ZazvPTqe8h ... l=Y&tp=105
Specifications
General
Power source ............................. 14.4 V DC (10.8 V to 15.1 V
allowable)
Grounding system ................... Negative type
Max. current consumption
.................................................. ... 10.0 A
Dimensions (W × H × D):
DIN
Chassis ..................... 178 × 50 × 161 mm
(7 × 2 × 6-3/8 in.)
Nose ........................... 188 × 58 × 23 mm
(7-3/8 × 2-1/4 × 7/8 in.)
D
Chassis ..................... 178 × 50 × 166 mm
(7 × 2 × 6-1/2 in.)
Nose ........................... 170 × 45 × 18 mm
(6-3/4 × 1-3/4 × 3/4 in.)
Weight .......................................... 1.7 kg (3.7 lbs)
Audio/DSP
Maximum power output ....... 50 W × 4
Continuous power output ... 22 W × 4 (50 Hz to 15 000
Hz, 5% THD, 4 W load, both
channels driven)
Load impedance ...................... 4 W (4 W to 8 W allowable)
Preout max output level/output impedance
.................................................. ... 5 V/100W
Loudness contour ...................+10 dB (100 Hz), +6.5 dB
(10 kHz) (volume: –30 dB)
Equalizer (16-Band Graphic Equalizer):
Frequency .......................... 20/31.5/50/80/125/200/315/
500/800/1.25k/2k/3.15k/5k/
8k/12.5k/20k Hz
Equalization range ........±12 dB
Auto equalizer:
(Front & rear & subwoofer 16 band graphic)
8k/12.5k/20k Hz
Equalization range ........+6 dB to –12 dB
HPF (Front/rear):
Frequency .......................... 50/63/80/100/125/160/200
Hz
Slope .................................... 0 (Pass)/–6/–12 dB/oct
Gain ...................................... 0 dB to –24 dB/Mute
Subwoofer (stereo/mono):
Hz
Slope .................................... –6/–12/–18 dB/oct
Gain ......................................+6 dB to –24 dB/Mute
pentavolvo
10-29-2009, 12:24 PM
i dont care what speakers you have when u turn on loud or bbe and turn it up they will sound like they are gonna blow... why headunits have it is beyone me
