no 1st
no 1st
Ok so normal driving in D or OD i have all gears, then tonight i felt like taking it a little higher in the RPMs so i dropped it in 1st at a stop light when i took off it was in 2nd. Its never done that before so i get home turn the car off then turn it on and put in 1st and it works...so then i go around the block and it still works. come up to my stop sign and then i put it in 1st take off and its in 2nd again, but in D or OD it holds first just fine...WTF??
I have the same problem, did you fix it ?
https://ls1tech.com/forums/automatic...ans-issue.html
No havent fixed it....i can get in and put it in first and it will stay, whenever i shift out say make a pass then slow down and go to put it in first again it will start in 2nd...but if i go ahead just move it to D or OD first engages just fine...dont have to turn it off for it to grab first....I do have to turn it off to manually hold first tho...ill scan for codes tho.
