Truck manifolds, stock k-member and 4" downpipe?
Is it possible? I am getting a truck manifold turbo kit built with a GT91 turbo and need to run a 4" DP. I have stock k-member right now. I'm on a budget and heard if you get spohn solid motor and trans mounts it'll fit? I have a T56 if that matters. It would save me a few hundred bucks which could be put to good use elsewhere. How harsh is it to drive on solid mounts? It's not an every day driver car, but will see a lot of street and little track. I figured a turbo k-member wouldn't be the greatest either street driving wise? Any suggestions? Where to buy the mounts also?
With the Spohn solid mounts, which I highly recommend, along with the spacer block for the trans. And a cheap $289 PA racing k-member, I can fit 5" along the passenger side. Bigger is better with a DP.
With a truck manifold kit I just did recently, and a BMR standard k-member, I could barely fit 3.5" pipe. I had to jack the engine off the mounts, lay the pipe, then put the engine back in place. Also had to grind on the block in spots for clearance, and to fit the v-band. I was not impressed.
So then I should get the spohn solid motor mounts and trans mount to fit a 4" thru. I don't want to get a k-member, is it bad to cruise on solid mounts? Its a street car, so I don't want to mess anything up. Is the turbo k-member the way to go in all honesty and keep the stock mounts? Also I don't know if a T56 has any advandage.
Ebay kit is too small, along with a T88. I am working with a member on here who is in the process of becoming a sponser and is making me a truck manifold kit. I need to fit a 4" DP regardless. Looks like the spohn solid motor mounts and trans mount is the way to go, now I just have to find a set.
I have driven my car on solid mounts from GA to TX a number of times No issues. I was looking at the bmr turbo k member but now Im looking at the pa racing bigger is better in a down pipe lol that is so true. But yes with some finess you can get the 4 inch to fit but by by ac.
Phoenix, is that stock K? I can't tell because I'm on my phone. From what I've been told you need both motor and trans spohn solid mounts. So where is everyone getting them and does it matter A4 or M6?
I've heard the tube K can make it worse? Beat to go with the turbo K or solid mounts. Phoenix you just have the motor mounts right? Bo trans? I'll probably do the trans just for good measure. That completes my hot side,now just have to figure everything else out, especially the electronics of boosting my car.
