Rear Bumpstops????????
Old 10-28-2009, 01:53 PM
griffs98z's Avatar
Default Rear Bumpstops????????
Does anyone know where I can find the rear factory bump stops for a 98Z28.
I do not want the polyurethane ones. Any info would be great......
Thanks
Old 10-28-2009, 02:02 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Thanks
Im not sure if the factory ones are even available any longer. Gm dealership would be my suggestion.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 10-28-2009, 02:04 PM
Chrome355z's Avatar
Junkyard?
Old 10-28-2009, 05:11 PM
97pontta's Avatar
I just got two new ones from my local GM dealership when I installed my Koni/Strano spring setup. I believe they were around $34 each.
Old 10-29-2009, 09:30 AM
Big_Bird_WS6's Avatar
i got two used ones with 36 K miles on it. but they look brand new.
say $40 shipped?
pm me if you want them. or pictures
Old 10-29-2009, 09:42 AM
TWS
TWS's Avatar
They are available through the dealership. I replaced both on my '94 Z28 in May. The originals had dried up and were falling apart.
Old 10-29-2009, 09:58 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Yea, Stealerships should have them or like said junk yards. Like TWS my 94's were basically rotted and blown out and my 2002 T/A w/ 44k look brand new. Go fig.
Old 10-30-2009, 09:02 AM
not to lose selling mine. but you can also do the poly ones like might mouse did.
https://ls1tech.com/forums/suspensio...ump-stops.html
^^^ theres the link
Old 10-30-2009, 09:46 AM
pjb
pjb's Avatar
he said from the start he didn't want the poly ones.
I would hardly consider the poly ones an "upgrade".
that must be a harsh impact. the stock ones are cushioned by design.
Old 10-30-2009, 11:26 AM
griffs98z's Avatar
I do understand that the poly ones would be good upgrades if you do allot of drag racing. I want to do something like a g-machine set up. I like track racing. So the softer stock ones would be better. Especially going into turns and such. I think that the poly ones would hit to hard....
Thanks everyone. I guess Stearlerships is the way to go..............
Robert
Old 10-30-2009, 12:38 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I actually run a bump stop on the shock itself in the back...not sure how great of an idea it is, but I needed the clearance for my wheels.
Old 10-30-2009, 03:09 PM
BandDirector Blk98ZM6's Avatar
WOW! SLP sold several sets last year for like $2.95 per pair...YES, less than $3 per pair. I bought 3 sets...1 went to a friend, one to use, and now I have a spare set. They were take-offs left over from the Firehawk/SS/WS6 program I guess...
Old 10-30-2009, 03:14 PM
MeentSS02's Avatar
I don't think the original poster would want those - the SLP bump stops were not very progressive (if at all), so when you hit them, it was harsh. The factory Z28 bump stops had more of a triangular shape to them, so they were a little softer on initial impact, and is why a lot of people prefer them over the SLP style bump stops.
Old 10-31-2009, 02:32 PM
The SLP bumpstops I bought were TAKE-OFF and identical to the stock ones I took off of my Z28...it was a foam type material. I'm guessing these were the factory bumpstop SLP removed to put theirs on.
Old 10-31-2009, 06:25 PM
MeentSS02's Avatar
Interesting...you got a good deal then
Old 11-02-2009, 01:04 PM
flathaulin's Avatar
pretty sure the only difference was the aluminum spacer added at slp for the 17 inch wheels...
Old 11-02-2009, 01:07 PM
pjb
pjb's Avatar
Wrong.
the bumpstops are entirely different.
Old 11-02-2009, 09:59 PM
DarkJuggalo's Avatar
hehe, i removed mine and havent looked back since
Old 11-02-2009, 10:04 PM
LS1vazquez's Avatar
Plus this. Mine were rotted out on my SS. I regret it though because I was driving it not long ago and I ran across a rut on a road and my fender dimpled. This was on a KONI shock also.
Old 11-22-2009, 09:53 AM
Average_Joe's Avatar
Mine were falling apart on my 01 formula so I stopped by a local salvage yard and found that all the 4th gens there had the bump stops broken off. I decided to look at the third gens and they were all intact, so I compared the two and they mount the same. I guess the ones used on the third gen f bodies were made from a more durable material.
Quick Reply: Rear Bumpstops????????
