Sts guys, little help please
My car is all done and sitting up at Speed Inc. They took it out on the street to do the drivability tune and at full throttle, the oil pressure buzzer started going off. A few people I talked to had broblems with the buzzer sending unit itself and just disconnected it, but I want to make sure it's not a serious problem first. What's the steps to diagnose this problem to see if there is oil pressure or if it is just a sending unit malfunction. Seems like all the people with the sts kits have basically the same problems and figured someone may have had this happen to them. Just looking for the steps to diagnose.
Thanks,
Ryan
Thanks,
Ryan
you could get a oil puressure gauge. Use an electric one so u just have to put a sender in. put it in the puessure line after the 2nd pump and could monitor it all the time then unplug the buzzer
Umm no with the above post... The buzzer is coming on because the pump is off. From your problem its the low to high switch. Find that switch and jump it to run high all the time. Also if your running the switch for the pcv make sure that green wire infront of it is not touching anything. If that fails check your relays in the sts harness and check the ground, verify that the pump is seeing 12 v under boost. If that fails re set the tq in the pump by turning it counter clock wise. Just loosen the bolts on top turn a 1.4 inch tighten them back down and see if it holds. If it dosent the pump is defective.
And No I dont work for STS LOL!!!
I had a relay go on me, was driving down road buzzer went off. I pulled over immediately, checked fuses. Popped the covers on the two relays in harness and BAM. One relays was corroded on the inside. Lucky I have backups in the car. Popped it in an all was good.
Oh they fixed it, picked it up yesterday and he showed me exactley what the did. Larry really takes time and I'm sure he would not send any car out of the shop unless it was absolutley perfect. I wouldn't think a company as big as Speed Inc. would want that kind of reputation.
Ryan
Ryan
