Easiest way to pull engine?
Old 10-29-2009, 12:02 AM
tylerdustin2008's Avatar
Default Easiest way to pull engine?
Sorry if this is in the wrong area.
I am going to replacing the rod bearings and main bearings in a 1998 firebird soon.. It has an LS1.
And Well I need to remove the engine.
Or do I?
Thanks.
Tyler
Old 10-29-2009, 12:10 AM
LSX Mechanic
Damian's Avatar
Yes you do.
Without a lift - From the top
With a lift - From the bottom
Old 10-29-2009, 07:03 PM
rdd014camaro's Avatar
yep gota pull the engine. easiest way ive found is from the bottom. If you have a car lift you can use it makes this process a sinch. check this link out. Great walkthrough http://www.myls1.com/showthread.php?t=1808. Are you replacing bearing because of knock? Were you getting bad oil pressure. Better make sure it didnt damage anyother parts while its out.
Old 10-29-2009, 09:46 PM
LastBlack02SS's Avatar
I used a cherry picker to lift the front of my car high enough to pull it out from the bottom on the entire front end. Worked great.
Old 10-30-2009, 09:16 AM
01ssreda4's Avatar
Cherry picker out the bottom FTW
Old 10-30-2009, 10:45 AM
I am going to be replacing them because of a knock. A young kid owned the car. And I am assuming he did not leave the correct amount of oil in the car.
So on a scale of 1-10 what would you all rate this engine pull at?
