f1-a on c6
f1-a on c6
hello every body i have a c6 ls2 a6 can i install the f1a procharger on stock short block ls2 on 6 psi / would i face any problem with the belt sliping or cuting
the bigger superchargers take more power to run,so you actually need more boost to make the same hp.if you do not plan on making 800+ rwhp,no need for the f1-go with a d1.plus they are physically bigger.
kinda the same thing as put a 100mm turbo on a car with stock heads, intake. you can only push so much air into the motor. like everyone said up top, if you plan on building a very high hp car then you might wanna consider the f1, if not, go smaller, bigger isnt always better.
The P-1SC, D-1SC, F and F-1A all have a 9.00 volute diameter. The F and F-1A are approx .38 longer in length.
Max boost we personally have seen out of a P series on a 402/408 cubic inch/cam/headers, etc is 12 psi, D series is 16 psi, F-1A is 19 psi.
The P and D series use a 4.10/1 gear ratio in the blower. The F series uses a 5.40/1 gear ratio. What this means is that with any given blower pulley, the F series is going to be spinning faster which means it will be making more boost.
The largest blower pulley that ProCharger makes is a 5.25. The larger the pulley, the less boost the blower will make. A 5.25 blower pulley on an LS2 with headers and exhaust on an F-1A would probably make around 10 psi of boost. Less boost if you live at a high elevation such as in Denver, Colorado. We had a customer who had a 5.50 blower pulley made for his LS1 GTO for his F-1A. With his aftermarket camshaft/headers/exhaust he was making 7 psi.
If you're planning on building your LS2 down the road, the F-1A is indeed a good way to go. Check out this LS2/402 we built and added an F-1A to it. Check out the last dyno graph and the torque it makes at just 2000 rpm.
http://www.exoticperformanceplus.com...Car.php?car=29 Bob
