question about TFS 225
Old 10-29-2009, 01:45 PM
PONTIAC SLP's Avatar
Default question about TFS 225
Hi , my cousin bought TFS 225 heads can he install the heads on LS1 bottom end ? because heads bore is 4.000 and the ls1 bore is 3.905
thanks in advance
Old 10-29-2009, 07:00 PM
CBIII's Avatar
short answer:no.
Old 10-29-2009, 07:53 PM
Brian Tooley Racing's Avatar
As long as you use a 4.0" bore gasket you'll be fine.
Don't forget that people use AFR 225's on 3.900" bore engines and they have a 4.100" bore chamber.
Old 10-30-2009, 05:17 PM
can we mill the TFS 225 to 60 or 59 cc ?
Old 10-30-2009, 10:53 PM
CBIII's Avatar
what size valves? arent you running them too close to the walls?
Old 10-31-2009, 10:26 PM
Yep, no problem.
Not at all, the TFS 225's only have 2.055" and 1.570" valves, the AFR 225 for example are 2.080"/1.600".
Old 11-01-2009, 12:10 AM
john563's Avatar
I hate to hi jack but its along the lines with the op post:
Anyway what is the down side to running TFS 225 vs 215 on a 346 C.I.
Do you lose low end TQ by doing so?
I thought about moving up to Trickflos 215 but thought what happens when I move up in C.I then I'd regret not having the 225..So jsut curious how the 225 will respond on a 346 vs the 215 heads
