What does this mean?
I jacked the front of my car up to check the front suspension.
The drivers side has what feels like 0.5-1mm of slack when pulling back and forth on the top and bottom, and no slack left to right.
The passenger side has no slack when pulling back and forth on the top and bottom, and has an unacceptable level (more than 4mm) of slack left to right.
What parts to I need to replace?
I have a lifetime alignment contract for this car so it won't be an issue to have it aligned after I replace the parts, but some basic tips to reinstalling the parts so that it is road-worthy would be great (so I can drive to an alignment center without chewing up the tires).
Damage to hubs, tie rods, ball joints, etc. are all possible considering where the components came from. So you think the front-back slack is tie-rods? Is the slight up/down slack on the drivers side something to worry about? I push my car hard. Is there a way to check other components for slack besides the wheel-tug test?
I did an engine swap from a car that had been rolled over (driver was fine). Re-used the complete suspension because aside from needing an alignment, all the bushings + components were newer and had half of the miles that the target car had. None of them are visually damaged/bent/etc.. The components on the target car were wearing out anyways simply due to having 140k miles on them.
Despite the donor k-member + front suspension parts being in a rollover, the alignment went pretty smooth. There was only one setting near the end that the new alignment tech was having difficulties with but otherwise it went alright. Spec was close to what I wanted but not spot-on.
that would be my guess, I think my car needs a whole new R&P. Also there is some damage where they make adjustments to the alignment.....It's going to cost me like 300 bucks for an alignment......GRRRRRRRRRR!!!!! Unless somone has some spare steering parts for donation!!! LOL
