98-02 a4 parts needed.
a4 - flex plate, aftermarket only
a4 - vehicle speed sensor pigtail with alot of wire if possible
a4 gear selector pigtail with alot of wire(i realy need this)this is the black connection that is on the a4 shifter.
a4 coolant lines, for f bodys (realy need this aswell)
also need, the gear switch on the 4l60e itselft, with all bolts and nuts to it.
I have the shifter pigtail, gear selector, and the tranny lines. Might also have the speed sensor connector, Ill have to check. Pm me if if still need them. im about 2 hours away from you.
