38mm or 44mm TiAL Wastegate?
I'm building a TT setup and am trying to decide which size WG to buy. I don't want boost creep and am looking to run between 8-10 psi or whatever it takes to make 550-575 at the wheels. Mods are in sig. Any help is apprecaited. Let me know if you need any more info.
Sorry guys, the turbos are 60 trims I believe. If nobody has had problems with boost creep with the 38s that will save me a few hundred dollars.
38's with that setup will be fine.
