Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Does anyone have a set of Retro fit SBC roller lifters?
Old 10-30-2009, 06:39 PM
victor3ranger's Avatar
Default Does anyone have a set of Retro fit SBC roller lifters?
I am wanting to swap my setup over to hydro roller but I need a set of retro fit roller lifters to use in my non-roller block, the ones with the tie-bars.
I can't afford to buy all new to make this swap happen so I was hoping that someone might have a used set laying around they would want to sell.
I know this is a long shot but I figured I would try.
Old 10-31-2009, 03:02 AM
In-Zane Moderator
ZONES89RS's Avatar
Man, most people want to sell the good ones that are 4-500 a set and they go for 2-300 used. Get the cheap set for 250-300 used if you arent going over 6500 RPM.
Old 10-31-2009, 08:59 AM
I am really hoping that I can find a good set used, so far that hasn't been easy.
Old 10-31-2009, 11:57 AM
In-Zane Moderator
ZONES89RS's Avatar
Yea, it wont be, Ebay is your best bet and since there are so many people looking for a set, the price still goes up too much.
That is why i use the 87 up SBC blocks. They use original equipment roller lifters and they are cheap, i steal them out of LT1s, 305 engines and L98 corvette motors all day. The retainers work forever, so if you got the retainer setup a new set of AC delco lifters are about 100$.
Might want to go that direction if possible.
Old 10-31-2009, 02:58 PM
87silverbullet's Avatar
Competition Products carries a retofit set from Howards for 269.95. I know people who have used Howards products and have no issues. Here is the link
http://competitionproducts.com/prodi...p?number=91164
Old 10-31-2009, 10:10 PM
ZONES89RS,
I do have one good roller block that is a 4 bolt main 350, but it is just the block, I just don't want to go thru the expense of building a new motor just to use the factory roller stuff, besides if I can retro fit my 406 it will have more HP potential I think.
87Silverbullet,
Thanks for the link, if I can't find a used set then I will have to save up the money to get some of those.
Do either of you know what all I will need for setting up the roller cam? I know that I will need a roller bushing, thick timing cover. Will I need to use some sort of shim or thrust washer to set up the end play of the cam??
Old 11-01-2009, 12:22 AM
Razor's Avatar
http://www.chevyhiperformance.com/te...cam/index.html
Old 11-01-2009, 07:43 AM
SoxXpupPeT's Avatar
why not just drill the block to fit the retainer ?
Old 11-01-2009, 01:57 PM
I didn't know that could actually be done.
I also thought that the lifter bore area were higher than the roller blocks.
Old 11-01-2009, 03:08 PM
His block would have to be the block with the 3 nubs sticking up in the lifter valley to use the factory roller set up found in 1 pc rear main seal blocks.
Old 11-01-2009, 06:30 PM
In-Zane Moderator
ZONES89RS's Avatar
No, you can actually make the stock OE roller stuff work on any older small block. Just still need to use a cam button and thrust plate.
Old 11-01-2009, 07:20 PM
Thats what I was thinking Zone, that I couldn't use any of the factory stuff.
Old 11-01-2009, 08:43 PM
Never knew that. How do you mount the spider piece?
Old 11-02-2009, 02:07 AM
In-Zane Moderator
ZONES89RS's Avatar
Just requires some drilling and tapping. I would have a machine shop do it, but you can do it yourself if you are confident enough.
Old 11-02-2009, 04:59 PM
Zone, I thought there were some other differences in the top of the lifter bores, I thought that the factory roller ones were milled down further so the dogbone retainers would fit flat and keep the lifters from coming out of the dogbones?? Am I wrong??
Old 11-02-2009, 10:01 PM
brokenbird's Avatar
you can do it you will have to drill some holes for the lifter tray and grind on them to clear the block but it can work since i did it in a .060 400 sbc
Old 11-02-2009, 11:30 PM
In-Zane Moderator
ZONES89RS's Avatar
Exactly.
Old 11-03-2009, 11:33 AM
Hmmmm, so the dogbone lifter retainers will work in a old non roller block without any mods?? Other than drilling and taping for the spider tray??
Old 11-03-2009, 11:51 AM
In-Zane Moderator
ZONES89RS's Avatar
Well, some grinding needs to be done for the dog bone too.
Old 11-03-2009, 08:50 PM
Oldsmobility85's Avatar
If you have pictures of that 406 block converted to fit factory hydraulic roller lifters and retainers I sure would like to see them. Thats very interesting.
Quick Reply: Does anyone have a set of Retro fit SBC roller lifters?
