oil in exhaust? what would cause this???
Old 10-31-2009, 10:04 AM
jwilsonf's Avatar
Default oil in exhaust? what would cause this???
just got it running runs great but smokes like a tar pit, 180-210 on all compression all plugs are non oil fouled, any suggestions?
Old 10-31-2009, 10:05 AM
jwilsonf's Avatar
by the ls1 1st gen.. 80mm tb, trex cam
Old 10-31-2009, 10:38 AM
livefast1's Avatar
what did you do? new motor build? heads cam? could be anything really check your pcv system first thats the cheapest, next would be valve seals and then piston rings.
Old 10-31-2009, 11:06 AM
jwilsonf's Avatar
2001 ls1, cam swap trex, pac springs, 80mm tb, engine has 67000 miles.. no way rings holding that good of compression??checked pvc its good, only thing it only pulling about 10-14 on vacuum and didnt know if that was normal with that big of a cam... plugged vac off on side of intake and bothe small llines behind intake are plugged.. when i first fired it off it didnt smoke at all, went to put exhaust on and ever since it smokes when it gets up to temp..
Old 10-31-2009, 11:07 AM
jwilsonf's Avatar
oh yeah thought if it were valve seals it would killing one of the plugs, but there clean..
