fast 92 intake mani
Old 11-01-2009, 06:02 PM
maxspeed96ct's Avatar
Default fast 92 intake mani
Im looking into buying a fast intake manifold soon...
What else is needed ?
Fuel rails or anything else I should consider into my budget ?
I plan on getting the fast 92 with a ls2 90mm and the wireing harness..
anything else I need?
Old 11-02-2009, 10:38 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
You will either need to transfer your intake o-rings over from your current manifold, or purchase new ones. The 05 CTSV should have already had the coolant plugs in the rear and crossover in the front, so you should not need to worry about buying those new. Be sure to use the valley cover bolts that are supplied with the intake manifold!! Other than that your rails, injectors, etc should all carry over to the new manifold. Let us know if we can help, we stock the FAST 92mm intake at very competitive prices ($799 shipped currently)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 11-02-2009, 12:43 PM
teke184's Avatar
my car needed a tune following the intake swap...was pretty lean up top.
and have you considered getting the intake ported...or doing a touch up yourself?
Old 11-02-2009, 02:53 PM
Red99TA's Avatar
Check out your LS2 TB when you get it to see the nice barricade to airflow that GM put in front of the blade - port that biotch!
