Do i have this right? 4l60E to th400....
Old 11-01-2009, 06:28 PM
Restricted User
1BAD_LS1's Avatar
Default Do i have this right? 4l60E to th400....
TCI flexplate $219.98- http://www.lmperformance.com/4050/1.html
PTC LS1 - TH400 Super Street Torque Converter $500- http://www.weberracing.net/p332/PTC-LS1-TH400-Super-Street-Torque-Converters/product_info.html (I think this converter comes with the ls1 pilot extension)
BMR TH400 LS1 Conversion crossmember with TA mount (TCC010) $239.95- http://www.bmrfabrication.com/F-bodyChassis.htm
BMR Full Length Adjustable Torque Arm (TA001) $269.95- http://www.bmrfabrication.com/F-bodySuspension.htm
Driveshaft cut to length ~$250~ - (I have an old steel driveshaft I could have shortened at a local shop)
Total: ~$1500 OUCH! lol
IF this is right then it needs to be put in the sticky like this, because even with the sticky its still confusing, I HOPE this is right (maybee im still confused)......
Parts needed for th400 swap:
th400 converter with pilot extension
TCI flexplate spacer not used
Conversion Crossmember
Adjustable Torque ARM
Custom Driveshaft
OR
th400 converter
TCI flexplate using spacer
Custom Driveshaft
Old 11-01-2009, 06:47 PM
98Camarod's Avatar
Stock 98 flexplate
PTC th400 converter for ls1 application - 300
bmr crossmember and driveshaft - 360
bmr torque arm - 195
lokar dipstick - 85
th400 with trans brake - 300
rmvb B&M shifter - 100
total is 1340 so far. I may have to get my driveshaft lengthened an inch or so, but we'll see on Wednesday when I finish it up
Old 11-01-2009, 06:56 PM
Restricted User
1BAD_LS1's Avatar
Originally Posted by 98Camarod
Stock 98 flexplate
lokar dipstick - 85
NICE! That is cheap!
The tranny im trying to get is $800
the rest of the stuff is going to be around $1500 unless i can find some deals on here
so ill have around $2300 in the whole swap... not to bad i guess.
Deffinetally let me know how it turns out! It will be a few months befor i save enough money to get all the parts....
Old 11-01-2009, 08:18 PM
Restricted User
1BAD_LS1's Avatar
if i understand this right... I can use a 98-99 stock flexplate with a th400 converter with ls1 pilot extension instead of buying the TCI flexplate?
Old 11-01-2009, 10:08 PM
RS_SS69's Avatar
^^^yes that is correct.
Old 11-01-2009, 10:13 PM
RS_SS69's Avatar
[QUOTE=1BAD_LS1;12448292]TCI flexplate $219.98-
BMR Full Length Adjustable Torque Arm (TA001) $269.95- [URL]
Total: ~$1500 OUCH! lol [QUOTE]
TCI flexplate can be had for $200
That is a good converter for the price $500
Th400 crossmember with tq arm provision is $195 from Yank
Why do you need an adjustable torque arm?
correct price on drivshaft shortening $250
A good th400 that will last under power is at least $1000 so at that your still at about $2000 which is great IMO.
Old 11-01-2009, 11:32 PM
Restricted User
1BAD_LS1's Avatar
[quote=RS_SS69;12449438][quote=1BAD_LS1;12448292]TCI flexplate $219.98-
BMR Full Length Adjustable Torque Arm (TA001) $269.95- [url]
Good info! Thanks!
Old 11-02-2009, 01:50 AM
Blown 98 Z's Avatar
Good info here....
https://ls1tech.com/forums/automatic...-th-400-a.html
Old 11-02-2009, 07:30 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
We offer a billet aluminum flexplate that is sfi approved and we also make an SR series 9.5" billet nonlock up converter for the th400 that is 495. The flexplate is 289 and we pay the freight. The converter would be custom built to your combo and will have the correct pilot for the ls engine.give me a call and support the sponsors on this board.
Greg
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 11-02-2009, 10:05 AM
Restricted User
1BAD_LS1's Avatar
Greg did not know you had converters in that price range... you will be hearing from me in a month or 2!
Old 11-02-2009, 10:12 AM
wajouba's Avatar
will the stock flexplate bolts fit on the Th400?? If i am using the following :
stock 98 flexplate
GM spacer
Stock Th400 converter
Quick Reply: Do i have this right? 4l60E to th400....
