Aftermarket Water temp sensor question
Old 11-01-2009, 07:37 PM
ssbandit158's Avatar
Default Aftermarket Water temp sensor question
I bought a spek water temp gauge that came with a sensor that goes into a water jacket. Problem is that the sensor threading is too small to fit into the head and I can't find an adapter because it's just barely too small. Does anyone know if water temp sensors are universal, I was thinking about splicing a factory sensor into the gauge instead of using the aftermarket one so that I can just screw it right in.
Old 11-03-2009, 01:29 AM
Just so everyone knows, after a lot of hunting I found an adapter sold by autometer part # 2277 that adapts aftermarket temp sensors into the plug on the passenger side rear of the car. Ordered it today, hope this helps anyone with this same problem!
Old 11-03-2009, 08:28 AM
TS6
TS6's Avatar
Yeah, be prepared for that not to work either. Mine didn't.
Old 11-09-2009, 02:02 PM
NHRATA01's Avatar
http://www.autobarn.net/eqoilpreselt.html
I'm going back about 4 years since I put in my autometer electric gauge, but one of those is what is needed. I THINK it was the M12x1.5 but don't hold me to it. I can say the one you need has a very thin wall so do not overtorque it otherwise it will crack.
Old 11-09-2009, 02:17 PM
69LT1Bird's Avatar
I had to enlarge the inner diameter a little for my sensor probe to go in all of the way.
Quick Reply: Aftermarket Water temp sensor question
