98 trans am Nitrous??
well i got a 98 trans am and i was wanting to get Nitrous in my car.. (mostly because cause my older brother just got an z06 corvette) and i want Nitrous before i got see him for Christmas. well i was looking at a kit
http://www.nitrousdirect.com/ls1-nitrous-kit.html
and i have no idea if it good are not so i wanted to ask for some help for picking a nos kit for my car.. and some things that need to be done be four i can install it? like a step by step thing would be amazing
please and thanks ))
there ar emany vendors on here that make quality kits like Harris Speedworks and Nitrous Outlet. you gonna need a lot more then just the basic kit to have a safe and effective kit.
-kit(i would go with a wet kit, you can search the difference and why)
-purge kit to clear air out of the lines before the spray
-bottle warmer to maintain the right bottle pressure
-depending on where the bottle is a remote bottle opener
-depending on the size of the shot, max would be like 100 shot on stock fuel pump, anything more you would need a new pump or boost a pump
-definetly a good dyno tune
-window switch or HSW microedge to control when it sprays etc
my recomendation would be the HSW single nozzle wet kit and the all out 3 package and you will be set all you need is a tune. dont know your mods or specifics on the car but if its a stick, stock clutch wont last long, auto will hold up for a little while. but even with a 100 shot without other mods, good luck keeping up with a zo6 because your gonna need more the a nitrous kit.
wow thanks a lot
but i have a stick shift .. and i need to replace the clutch BAD.... so like what would be the best clutch i can get for my car. nothing TO expensive lol
wet kit:
http://www.harrisspeedworks.com/prod...cat=136&page=1
accessory kit:
http://www.harrisspeedworks.com/prod...p?productid=12
i would say an LS7 clutch kit would hold the power for a while but your gonna have to go with a spec stage 2 or more for longer holding power. the LS7 can be bought new for like 400 i believe. you can have all the power in the world but if you cant put it to the ground there is no point in having it. so buy some drag radials too.
accessory kit:
Do your self a favor and do a google search on that comapny before handing over your credit card.. Buyer Beware!!!
There are many of better options available for your car. To better advise you on what would be best for your application can you give us the specifics on your mods and future goals?
Dave
Dave
