Widen Firehawk Wheels
Old 11-03-2009, 11:37 AM
Hawk170's Avatar
Default Widen Firehawk Wheels
Im going to widen my firehawk wheels. Of course i can only go one direction... how wide should i go ? How much backspacing is too much ? I have 315's to put on right now but i would like to go 335 ..... I have a shop that is going to cut the wheels and fit the spacer in place. I will have one of my employee's weld them up ( my best welder). I just need to know how extreme to go.
Old 11-03-2009, 04:26 PM
redracer1's Avatar
11" wheels for a 315 tire
12" wheels for a 335 tire
not sure on off set and spacers
Mabe this will help
http://www.1010tires.com/TireSizeCal...?action=submit
Old 11-03-2009, 07:23 PM
69TA's Avatar
the problem is you also need to add lipage to the front of the wheel as well as the back.
you can't go too wide 1"+ in the back with out running spacers or mini tubbing the car
Old 11-04-2009, 06:03 AM
toadzq8's Avatar
To get 12" under the back it will require sheet metal work, not for the faint of heart.
Old 11-04-2009, 10:05 AM
naperws6's Avatar
I bought my firehawk and the rear firehawk rims are widened to 11".. I think the old owner said he had them done at wheel of america about $500 total shipped they cut the inside of rim and you need to run a 1" spacer which are about $60-75 on ebay. no need to weld on scacer. I really wish they would have widened the front of rim and put a lip on it, which probably can't be done. my opinion it't really not worth $500 I would have rather saved my money and bought a sick set of ccw 505.
