FAST 90/92 Guys Come In!!!
Old 11-03-2009, 03:11 PM
wytry's Avatar
Default FAST 90/92 Guys Come In!!!
Looking to invest in a FAST 90/92 setup including a matching throttle body...I planned on keeping and maybe porting the stock MAF...so my question is...What do you do or have any of you done about the ducting (don't know what else to call it) between the stock MAF and stock throttle body. I mean the new throttle body opening will be quite a bit larger, so I wouldn't imagine the rubber ducting could be reused, right? Is there something I can buy or do you guys make something yourself? Thanks
Old 11-03-2009, 04:25 PM
2000NavyZ's Avatar
ive got a 92mm throttle body w/ a stock maf, along w/ a friend of mine. we just heated the stock bellow up w/ a torch and stretched it over the throttle body, it was pretty easy. you just need a bigger hose clamp.
Old 11-03-2009, 09:20 PM
panterx1's Avatar
I have the 92mm and re-used my SLP smooth bellow on it...it stretched out enough.
Old 11-04-2009, 12:33 AM
Detoxx03's Avatar
Mine went over without a problem
Old 11-04-2009, 07:15 AM
teke184's Avatar
little bit of silicon spray, a 2nd set of hands, and a pair of screwdrivers and my stock bellows fit just fine.
Old 11-04-2009, 01:14 PM
wytry's Avatar
Ok nice! Just wasn't sure but thanks guys!
