kevins2000LS1
11-03-2009, 09:38 PM
Had the car tuned a few weeks or so back and had the VATs tuned out also. But with it tuned out will the key cylinder still cause the often no crank issue? I thought all the cylinder did was move a rod to the ignition switch on the column.
I had mine tuned out and it still SECURITY'D on me. Had to install the Resistors in the Column to fix it. Havent had an issue since.
2001NBMZ28
11-05-2009, 11:01 AM
Yeah, you need to bypass it with a resistor. The BCM controls VATS - you can tune the PCM to ignore the BCM fuel enable signal, but not the starter relay signal.
