wtb underhood fuse/relay box (or just the little female blade terminal connectors)
Hi,
I'm looking to buy:
an old under-hood fuse/relay box WITH the little female blade terminal connectors in it...
OR
just the little female blade terminal connectors from the box
OR
does anyone know where I can get the blade terminal connectors new?
I am putting an EWP relay in an empty spot in the box, where there are no existing female blade connectors, and standard bulk female blade-type connectors obviously don't work.
I'm looking to buy:
OR
OR
GM dealer will have the correct connectors. You just need to know the year/make of the car and they can get you the terminals. Or if you want I can sell you a 98 F body engine fuse box for $20 shipped in the lower 48 states. There should be enough wire left on the connectors to solder wires to. Up to you.
