Kyle's KY-Turbo Tube Header T4 Hot Parts "Non A/C"
Old 11-05-2009, 12:44 AM
Josh@KY-Turbo's Avatar
Default Kyle's KY-Turbo Tube Header T4 Hot Parts "Non A/C"
I am sure Kyle wont mind me posting a little teaser of what is heading his way. A while back he ordered a 6.0L manifold setup with a TC78. That setup was recently sold to fund his new Tube headers setup. 304L Stainless 1 3/4 headers, 3" Charges Pipe, and 3" DP for the TC78. This is following the same rule as his 6.0L manifold setup. Simple effective. NO A/C. The primary size on the headers and the 3" Charge pipe are a little on the over kill side of things. Hell with he new T4 91mm that is now available we wanted to be sure there was plenty of growing room with just a simple DP change.
Enjoy the pic’s.
For what it is worth. The Up coming A/C setups will follow the same basic design.
Old 11-05-2009, 01:14 AM
RS_SS69's Avatar
Nice Josh, price on this setup? for just the hot side that is pictured?
Old 11-05-2009, 02:07 AM
chuntington101's Avatar
any rerason for using 3inch piping over the normal 2.5inch???
Looks stunning!
Chris.
Old 11-05-2009, 07:50 AM
Fireball's Avatar
Looks stunning!
Chris.
definately nice craftsmanship, but I personally would've used 2.5" piping....
Old 11-05-2009, 08:03 AM
LS1TECH Sponsor
DrTurbo's Avatar
The kit will indeed fit the new T4 91mm unit. Should be a beast kit from 76 to 91 for almost anyone that wants a solid well built street kit. Not some chinese cloned kit. Excellent work Josh. Make sure somebody doesn't buy this kit and clone it too....lol
Old 11-05-2009, 08:23 AM
383lt1impala's Avatar
The headers look . What's the price on those?
Old 11-05-2009, 08:31 AM
1CAMWNDR's Avatar
For the A/C it looks like you could just turn thte turbo 180° and send the downpipe down the driver's side since you are using the turbo k-member.
Beutiful work as usual. I wish I had the means to look into this; but when my motor blew last year I built a hot N/A set up since it looks like I will never get around to the turbo world.
Old 11-05-2009, 09:54 AM
LS1RedZ's Avatar
Wow. That looks killer!
Old 11-05-2009, 10:15 AM
What's Pictured is roughly $2500 + the ride.
Headers alone roughly $1200 + the ride.
Contact myself or Derek@KY-Turbo if interested.
I run bigger with 1 3/4 Primary on the headers and 3" on the Charge pipe for growing room and to stream line the T4 and T6 setups with similar parts. With the Airflow that is afforded with LS1 Heads and the efficiency the LS1 engine have I have not see a huge drop in power from 2.5" to 3". I have done alot of testing on this.
The A/C setup will rotate the Turbo 180* and send the DP out the drivers side, that is exactly right.
Imitation is the biggest form a flattery. Karma is a Bitch. I have a unique way for swinging Karma one way or another in this industry .
Old 11-05-2009, 10:36 AM
SSU Moderator
RyanJ's Avatar
Why does no one ever route the WG back into the downpipe. Do you guys like that sound? It is a plumbing issue? Seems like you could do it easily there...
Old 11-05-2009, 11:34 AM
Kyle wanted it vented to atmosphere. Less chance of having boost creep issues. I typicaly on go back to the DP when requested. I like the sound of an open WG.
Old 11-05-2009, 12:50 PM
XtremeDime's Avatar
Open wastegate sounds awesome
Old 11-05-2009, 12:52 PM
2002RamAir's Avatar
Damn Josh... Looks better than the teaser pic you sent me yesterday... I can not wait to get it... Tomorrow whoohoooooooo!!!!!!
Old 11-05-2009, 01:08 PM
95cobby's Avatar
That looks badass! Am I going to have to come down and help you put the new setup on to Kyle!?
Old 11-05-2009, 07:19 PM
frcefed98's Avatar
Looks great Josh
Old 11-05-2009, 08:16 PM
Eric Bazan's Avatar
Nice set up
Old 11-05-2009, 09:07 PM
crazy willy's Avatar
hey man you think you can build me a set of headers.im building a twin set up .if you can let me no how much and the turn around on them thanks man really need a set its for a 98 ss comaro
Old 11-07-2009, 10:43 AM
Black Sunshine/ 00SS's Avatar
What's the power, boost difference between that and the truck manifolds? Looks great.
Old 11-07-2009, 10:28 PM
Honestly they both do the job very well.
Old 11-08-2009, 08:41 AM
So, it's just eye candy? It looks great, but if there is no difference, then I'd prefer to spend the extra money on the turbo, and intercooler. Keep up the great work.
Quick Reply: Kyle's KY-Turbo Tube Header T4 Hot Parts "Non A/C"
