New LS1 Owners - Newbie Tech - How & where is the HP?
3+3Crawler
11-05-2009, 04:31 AM
241/253 .571/.571 108+0
Where is the power range for this cam ?
Thanks, Jeff
teke184
11-05-2009, 07:00 AM
high...and it will idle horribly
2002t/a06
11-05-2009, 11:25 AM
I concur.
406malibu
11-05-2009, 11:29 AM
I concur.
I concur with your concurrence.
SOMbitch
11-05-2009, 02:15 PM
How many cubes????
twitchtwice
11-05-2009, 04:10 PM
yeah what they said. thats a huge duration with a very low LSA
3+3Crawler
11-05-2009, 04:33 PM
Stock .. LQ9 with mild hand ported 317's and carb conversion Performer RPM manifold. Running propane for rock crawler. Also running a MSD 6010 and LT headers.
I'm currently in the market for a strong mid-range cam ... also trying to understand how duration/lift/LSA translate to Hp./Tq. in the power-band.
These cam specs intrigued me.
Jeff
SOMbitch
11-05-2009, 06:31 PM
http://www.ls1tech.com/forums/generation-iii-internal-engine/772576-got-cam-heads-rocker-machining-questions-about-ls1-ls2-ls6-read-me-first.html This will help. I usually defer to the real knowledgable cam guys on here but I will say for your purpose a smaller duration cam will be better. Cubes, weight, RPM range, gearing, etc... all need to be considered.
3+3Crawler
11-07-2009, 07:36 AM
Don't know if my spec. sheet will help you much as it's a bit different from most around here.
TH400 to 4-1 reduction transfer-case , custom super low flash Tq converter that stalls around 900-1,000 rpm.
4.88 diff gears, weight around 5,500 lbs....looking to make strong mid-range power. It needs to be strong between off idle to 5,600 or so.
From what I've read a low LSA brings the usable power range down but high lifts and long durations do just the opposite?
Jeff
406malibu
11-07-2009, 10:19 AM
Low LSA brings the power up from what I've always seen...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
