RWHP on my 370??
Old 11-06-2009, 09:34 AM
Restricted User
Irby's Avatar
Default RWHP on my 370??
Is it possible to hit 500RWHP in my TA with this set up?
6.0 Iron block, 4.03 Bore
LS1 Crank, Forged Rods & Pistons
MS4 Cam
Patriot Stage 3 243's, 2.08/1.6 valves
TSP 1 7/8 headers
Ported fast 92
Fast 92 TB
Ported stock maf
42lb Injectors
And its through a 6 speed and 12 bolt.......
Old 11-06-2009, 09:41 AM
jmm98LS1's Avatar
You'll be up there. Mine made 495rwhp N/A through a 6spd, 3" steel DS, 9" and 325 drag radials with a fairly conservative pump gas tune.
Old 11-06-2009, 10:45 AM
adam1803's Avatar
Should be pretty close, my 364 made 470 through a t56 and a MUCH more aggressive camshaft, and bigger diameter headers, not sure if i'd say your heads are any better then my Katechs, but should be about the same at least.
