Drag Racing Tech
setting up pinion angle???
Old 12-09-2003, 03:37 PM
more carbon's Avatar
Default setting up pinion angle???
can someone tell the proper way to set pinion angle on a 12 bolt car with adjustable t/a please and thks.
Old 12-09-2003, 04:46 PM
GeorgeC's Avatar
IMHO, this is the only "right" way to do it...
http://www.rosslertrans.com/Tips/Pinon.htm
Follow the example labeled for ladder-bar...
Old 12-09-2003, 09:19 PM
thks. alot for the connection,very helpful and much appreciated!!!gotta go and take the drive-shaft off now??? thks. pat
Old 12-10-2003, 08:31 PM
GeorgeC's Avatar
You don't really have to take the driveshaft out, as long as you can get a good reading off the pinion yoke on the rear end, and the tailshaft on the tranny...
It is easier with the driveshaft out, though...
