Tapping oil pan
Old 11-06-2009, 10:05 PM
XtremeDime's Avatar
Default Tapping oil pan
So I finally got my oil pan dropped and Im going to tap the front of the pan for my drain. It looks like most guys are tapping and threading the hole. Is it possible to just drill a hole, put the fitting in with a seal and nut also with a seal on the other side?
Old 11-06-2009, 10:20 PM
elias_799's Avatar
drill and tap the hole and use thread sealant on the fitting.
Old 11-07-2009, 01:23 AM
XtremeDime's Avatar
Is that the only way to do this?
Old 11-07-2009, 01:29 AM
bondosgto's Avatar
some guys return to a valve cover, or the oil fill tube.
Old 11-07-2009, 01:30 AM
XtremeDime's Avatar
I dont think thatll work, without a pump.
Old 11-07-2009, 04:08 AM
98Camarod's Avatar
You can weld a bung on there if you don't want to drill and tap it
Old 11-07-2009, 04:55 AM
elias_799's Avatar
^^ i think that is the best way, but you have to have a tig welder
Old 11-07-2009, 08:27 AM
Photochop's Avatar
You can drill a hole in the pan and use a bulkhead fitting - that works pretty well. Use a 10AN bulkhead with a nut on the back (inside the pan), and make sure to use a good sealant with it.
Old 11-07-2009, 09:15 AM
MUSTANGBRKR02's Avatar
What size tap are you guys using for the drains?
Old 11-07-2009, 12:04 PM
taws6m6's Avatar
I used the bulkhead fitting as well, with a seal on each side. I can't weld aluminum,, and like to do everything myself
Old 11-07-2009, 07:52 PM
XtremeDime's Avatar
Can I see some pics of the bulkhead fitting installs?
Old 11-07-2009, 08:50 PM
tim99ws6's Avatar
Mine is -12an welded into the pan.
Quick Reply: Tapping oil pan
