Another great night of racing at PBIR. New PB.
Old 11-06-2009, 11:24 PM
Restricted User
98Z28CobraKiller's Avatar
Default Another great night of racing at PBIR. New PB.
I made 3 passes. **** was hooking good! Lost the first time slip but it wasn't the best one. BonnarLS1 got all the passes on video. I also got data on 2 out of the 3.
I'm going to call it 11 psi. Was jumping around between high 9# to low 11# on the log. I think that the controller will work better as I get farther away from the wastegate spring pressure.
2nd Pass (Best Pass so far)
60' 1.375
330' 4.062
1/8 6.283
MPH 110.67
1000' 8.191
1/4 9.805
MPH 139.76
3rd Pass
60' 1.424
330' 4.154
1/8 6.386
MPH 110.53
1000' 8.288
1/4 9.892
MPH 140.71
Best night of racing that I have had in a long time.
http://www.youtube.com/watch?v=6cxDd...layer_embedded
http://www.youtube.com/watch?v=Ciw8S...layer_embedded
http://www.youtube.com/watch?v=obES6...layer_embedded
Old 11-07-2009, 08:07 AM
darooke's Avatar
nice, That is moving, I like the 1.375 60ft and you gained 30mph in the back half. That is a well rounded car. Congrats.
Old 11-07-2009, 08:16 AM
HUNTER02SS's Avatar
Congrat'a. Turn up the boost some and you will be looking at bottom 9's!
Old 11-07-2009, 08:29 AM
cablebandit's Avatar
Congrats on the new best. that 60 is awesome. cant wait to see the video
Old 11-07-2009, 09:07 AM
Restricted User
Video's up
Old 11-07-2009, 09:10 AM
damn that bitch looks good leaving!!!!!!!!!!!
Old 11-07-2009, 12:44 PM
96silverram's Avatar
That's just plain sick !
Old 11-07-2009, 12:56 PM
TheFallen's Avatar
that car leaves very impressively
Old 11-07-2009, 01:12 PM
Restricted User
Originally Posted by van383
i really thought about running the hp tuners and stock ecu etc.. felt i would not have enuff inj to do the hp i would like?? what ur duty cycle on the 80lbs now? and where u expect them to be when u turn it up? was looking into the bs3 for mine.. im starting with noe ecu or harness anyway..
On the best pass I was seeing 73% inj duty cycle. As I turn up the boost the pressure goes up so it will stretch out the injs a bit. I'm estimating 650-700 rwhp right now.
Old 11-07-2009, 04:24 PM
van383's Avatar
got ya looks like turning it up will bump them up there to 100% mark... u where doing 130 dc with old set-up u plan on doing this again with new build? thanks
Old 11-07-2009, 04:35 PM
Restricted User
I was hitting the crazy duty cycle because I was running a single intake 255. Once I put in the MagnaFuel 4301, that duty cycle came down into 60's. I am curious to see how the duty cycle is effected by additional boost as I turn it up. More boost = more fuel pressure on a boost referenced fuel system. Right now, thanks to the stock 98 PCM, I'm limited to about 15 psi on the MAP sensor. The current setup should get me there. Beyond that, I will be switching over to the MegaSquirt2. At that time, I will add meth to get the rest of the way to my 8.8-8.9 goal.
Old 11-07-2009, 04:42 PM
van383's Avatar
yeah got a customer with 98ecu on his d1sc car and same thing limited boost, why the megasquirt 2 verses bs3 or fast etc?
Old 11-07-2009, 04:51 PM
van383's Avatar
if i read right it says up too 21psi with the megasquirt?? will it process more do u know? i say 400.00 is why go with it over them lol.. but did not see for the guys who do not have a harness for the ls stuff does it tee in? or come with something else..
Old 11-07-2009, 05:08 PM
Restricted User
I dont have many of the answers on MegaSquirt as I am no expert. My reasons are that it's cheap and it does everything that I will need. Don't know yet about the harness but I have access to a 98 (mine) and a 99 harness so I can cut one up and repin it for the MS no problem. I'm pretty sure you can run over 30 psi of boost with it.
Old 11-08-2009, 02:10 AM
venom ws7's Avatar
man your car launch hard very nice and Congrats on your new best.
How much boost are you launching at?? what 2step are you using??
Old 11-08-2009, 06:31 AM
Restricted User
Ligenfelter LNC-002 set at 3800 RPM and 0 adv/ret. Launch boost is about 6 psi.
Old 11-08-2009, 11:08 AM
RS_SS69's Avatar
Very nice, I like the way your car leaves! Cant wait to see you turn up the boost and lean on it.
Quick Reply: Another great night of racing at PBIR. New PB.
