Only smokes when warm???? WTF
Getting oil burning problems but only when it is to operating temps, i dont understand the prob, i have a catch can on the pvc ( no breather on the can), the other tube going from the valve cover to the tb has a brether on it now and the hole it hooks too on the TB is plugged... i just did a cam swap all new everything, cam, ls6 oil pump, springs, ls2 chain,valve seals retainers and all... it did smoke before the swap i was hoping it was just valve seals but it didnt fix the problem.
I am still getting oil in the intake even tho i have the catch can and the other tube plugged and a beather... could it be because i dont have a brether on the catch can? or what other problems could it be?
I also noticed when doing the cam swap i hook up air to the cylinders to hold my valves, it seemed to be leaking air into the bottom of the motor... i figured it was normal cause of the ring gaps, it was leaking kinda bad tho... still not th prob with oil in my ontake tho
i really want to get this figuered out it use to drive me crazy... right now the motor is out of the car and down to a short block cause i was planning on doing a 5.3 swap with a truck manny cutom turbo kit, but due to funds i am think of just putting my motor back together with some cnc heads and shoot some spray maybe a 100-150 shot...
I want to get this figured out before i put the motor back together in case i need to due rings... maybe forged rods and pistons too while i am in there lol
No one? lol sorry i have tried using the search but i found nothing... wouldnt you think if it was the rings in would smoke all the time instead of just when it is warm?
No i didnt use any sealent i was wondering about that, can they leak oil into the chambers?
Also what machine work would i have to do to do the rings do the cylinder walls need to be cleaned up? and if i just do rings will the stock pistons and rods hold a 100-150 wet shot ok?
Sorry this is the first car i have really had a chance to break down and learn things with, so sorry if these are dumb questions or anything
