12.2's now whats neded to get in 11's?
Ok guys im going to try and get in the 11's without going into the motor (ie cam). Im wondering which bolt-on dollar for dollar will net me the most gain. Or just say screw it and add a 150 shot and go in the 10's for the same money as the rest of the bolt on's. Heres my options to what i can add. Car currently has stock 3.23's
3.73 - is traction going to be a issue with the ss4000
UD pulley
ram air kit
cut out
practice is going to be the free part!!.
I run a 12.2 with the current mods and im sure i have room for improvement just looking for the right direction.
UD pulley
ram air kit
cut out
I dunno. I did !FRA
Where you cut the underside/backside of your radiator support under your lid. It sure seems to work seeing how fast my filter gets dirty now. I dunno, it takes up air from the air dam that way, but I don't know. You can find that article with pics on www.installuniversity.com
I just cant justify spending 200 bucks on an SLP FTRA or whatever kit lol
I dunno. I did !FRA
3.73s would get you into the 11's but for how long idk...stock 10 bolt can hold up for a few hard launches...if your on et streets with 3.73s and et streets itll hold up fine...
UD pulley
ram air kit
cut out
UD pulley
ram air kit
cut out
Stock tune or an aggressive tune with racing fuel?
Spare tire, jack, front sway bar has been removed im not going to remove my seats and stuff like that. Car has been tuned for 93 octane just need to fine tune it.
Dang 25 hp difference i fiqured that the 40 series would flow better than the 80 series crossflow, but thinking about the cutout, taking off the a/c belt and bypassing the powersteering pump for track use. And maybe getting with chris1313 for one of his cold air kits.
cutout would be the very FIRST thing i would get. The flowmaster you have is super restrictive. Gears would help you as well depending on what your 60ft is right now. Cutouts and gears should get you into the 11's no problem.
I dont know about a camaro but my ws6 gain just over a tenth and 4mph by taking out the baffles and sealing the box. Those are some good times for a bolt on car though i wish i could get those times with my ws6 my best was 12.76 at 110mph but if i was you i would try the cold air/ram air, cutout, and gears that and a nice day should be 11s.
