Removing Crank Gear...problems
I had better luck using a three jaw that could convert to two jaw. I used it in two jaw mode. Also with a 3 jaw puller just get it as square and straight as possible and get the teeth as far engaged as you can, when they try to slip off, just tap them back seated again. This worked well for me.
That gear is heat expanded installed from the factory. They heat the gear and then quickly install it. It is a bear to remove it. Use a good puller that has bolts to keep the jaws from spreading. I usually cut them off if the crank is out of the car. If its in the car and you just want to freshen up the chain and gears it has to be pulled off. Sometimes it has to be heated with extream caution. The heat will expand the gear for ease of removal. Mostly all new engines use heat fit gears.
Hey Vettenuts, so which tool are you talking about?
I've found your thread on valvetrain specs and have it ready for when I am putting heads back on.....
Can I just leave the gear on and run the new LS2 timing chain and cam gear?Ive read the pros and cons, but I guess peace of mind knowing a newer gear is on more important to me. I guess though it all determines how much a PITA it will be, this is the last thing to be done before installing all the new goodies.
So what tool is it?
So what tool is it?
1 Post
So what tool is it?
So what tool is it?
So what tool is it?
So what tool is it?
Found it, here is the tool. You use it with a puller you can rent from Autozone or buy the puller if you need it for other things like I did. This tool attaches to the standard puller. I will post a photo of how to use tonight.
Kent-Moore Tool for Crank Sprocket Removal
Thanks for the photos Vettenuts, I just may need to go ahead and buy that tool to remove the sprocket.
I installed the ls2 chain with the factory cam gear and crank gear and have some decent slack in the chain. So I tried with the factory ls1 chain and same gears, resulted in little less slack. I then installed a JP Performance cam gear with the stock crank gear and ls2 chain, still decent amount of slack. I am curious if switching the crank gear will show any result.....I mean, should there really be this slack issue with the ls2 chain. Its not enough to make the chain jump teeth or anything, but still enough slack that leaves me wondering if and when is something gonna happen?
Any slack issues with ls2 chains? I know a pic would tell more, I'll work on that.
1 Post
There is a couple of ways to play this. I usually buy the tools and keep them for future use. If you don't think you will use them you can sell them here on tech and get back some of the money. I will say one thing, the proper tools make a huge difference on how easy the job goes.
