Side and Corner Markers
Old 11-08-2009, 09:21 PM
Phstratton's Avatar
Default Side and Corner Markers
I'm looking for black side and corner markers for my 1996 Camaro. Where can I get these?
Old 11-08-2009, 09:49 PM
crimson_bird's Avatar
ebay... they've got em all
Old 11-08-2009, 11:01 PM
Phstratton's Avatar
I heard ebay ones leak though. Is that true?
Old 11-08-2009, 11:17 PM
hitmanws6's Avatar
all aftermarket ones do. its an easy fix. just buy rtv silicone and put it around the light. should fix any leak issues
Old 11-09-2009, 05:31 AM
TooFastT/A's Avatar
Why not Niteshade your stock lenses? Not that hard to do and they look killer, plus they don't leak!
-Justin
Old 11-09-2009, 08:58 AM
Phstratton's Avatar
-Justin
Because I've been told that the amber vht'd won't look as good as clear ones that are vht'd.
Old 11-09-2009, 11:01 AM
spikester7878's Avatar
i recently did something similar to vht on mine and i think they look pretty sharp with the factory color
Old 11-09-2009, 11:15 AM
Phstratton's Avatar
What did you do? They look good.
Old 11-09-2009, 11:21 AM
i actually used paint they use for tint on model cars ill see if i can find the can i put on two coats wet sanded them down and buffed em out. i did the same on the taillights as well. if you loof at them at an angel u can see the original color through it but i think it looks pretty good like that. and with the factory lights you can see the lights no problem to include the break lights during the day
Old 11-09-2009, 11:22 AM
ill see if i can get a closer shot of em for you
Old 11-09-2009, 11:24 AM
you can see how the color shows on that picture
Old 11-09-2009, 04:08 PM
legendarysouls's Avatar
i have had DEPO clear side markers for like 2 years now and NEver had a problem with leaks or water
Old 11-09-2009, 04:30 PM
whoever said that doesnt know what they're talking about, and probably hasnt even done it. i have seen plenty of other people do it, and have done it myself and it will come out the same. the vht covers over any color the same way. the ONLY reason someone may think it doesnt look as good, is if they only wanted a very light clear/smoked look, which is something you can accomplish with clear, but not amber. if you want them fairly dark though, it doesnt matter which you use, stock will look fine.
Quick Reply: Side and Corner Markers
