6Cyl springs????
6Cyl springs????
Hey guys , This is the deal. I wanted to lower my 98 z28 so bad I could'nt wait to get the money and buy the sporlines and shocks I am dieing for so I cut the springs 2 turns in the front and removed the the ruber top springs in the rear..The car looks real good (at least to me) but it rides like ***.(The front at least)... I still don't have the means to lower it the right way but I can get a pair o6 cyl complete shock and springs assembly for the front.. What will be the difference in ride and hight in the front witht the 6cyl springs. And should I go with 6cyl springs in the rear also and install the ruber tops again.. If not Iam just going to find stock ls1 springs and wait.... What do you guys think..any info will be helpful Thanks
Rear spring rates for the 98-02 V6/V8 cars are the same. So you're not going to notice a difference there. And there isn't really much of a difference in front spring rates for those year models either (Iron V6 versus Aluminum V8). If you're dead set on using V6 springs, try to get some off the 93-97 models, as they use a lower spring rate than the later years.
Honestly, I think you'd just be better off and happier saving up for some proper lowering springs.
Thats what I thought.. Iron v6 should be the same as th aluminum v8.. I have 93-97 springs.. I would just like it to ride nice for now but not as high as it was stock.. I am going to try the 6cyl springs that I have and I'll let you guys know what happens.. Thanks for the help..
I think in the 2001 and 2002 models they got z28 suspension, I know everyone talks so much about the intake being the ls6 intake but you would also be surprised of the amount they decided to just use on the v6 model that they had from the v8 model.....I have both, and to my knowledge they are the exact same. The difference in front ends only being in the steering to accommodate a larger motor...
Please somone try to correct me if I'm wrong.
V6's didn't have the PS cooler or larger swaybars except for the SLP Firebird GT (yes, there was a special edition of the V6). Otherwise, the V6's had a smaller front and rear swaybar that's why the majority of the V6 guys looking to improve their handling on a budget go for LS1 takeoffs.
Exactly, in my z28, it doesn't have a cooler. I have had both my cars on stands, and like I said, the springs/shocks are the same, which from what I read, were actually different then the 2000 v6 Camaros.. If I could find a 2000 or older v6 to compare with I would, but just comparing suspension, its the same, steering is a tad different from my 2002v6 to my 2002 v8 although I couldn't tell you for sure what's different without looking...maybe I just need to go take some pics....
If you care at all about ride quality sportlines shouldn't even be considered, they are arguably the worst spring for our cars because the rate is way too low for the drop, causing you to slam the bump stops harder and more often.
A cheap alternative for you right now could be getting some LT1 front springs, which generally seem to be lower than LS1 springs and also have slightly more rate. But now as you have experienced rushing things and doing things the cheap way usually leave you with cheap, undesired results. Pick up some LT1 springs and put them on for now, then save up and research on shocks and springs and do it right one time.
You need to search.
Thanks for the info..and yeah your right thats what happens when you rush stuff..I have a set of lt1 springs but I thought since the lt1 is heavier then the ls1 It will raise the car too much...
