10 Second Club - Another...Do you think its possible?
02SLOMARO
11-09-2009, 05:39 PM
Here is the set up i have that is going to be used this next spring. everything is going to the machine shop to get checked and balanced this week.
eagle 4340 4.000" stroke crank
eagle 4340 6.125" h-beams w/bolt upgrade
diamond 11560 nitrous pistons
tsp texas giant cam
factory casting heads with extensive port work resembles a ported l92 head
harland sharp rockers
gmpp single plane intake w/edelbrock plenum elbow
no tb yet but at least a 90mm
lt's
udp
aeromotive rails w/42lb injectors
255 pump with wire kit
and a little n2o if needed.
how close to the 10's should i expect all motor or am i being a little to hopefull. i will be running completely gutted and running through a six speed.
