LQ9 Cam info neded for shift points.
Old 11-10-2009, 09:47 AM
WS6HUMMER's Avatar
Default LQ9 Cam info neded for shift points.
I have a friend with an 02 Escalade telling me to make it shift @ 6800 because thats where it makes peak power at. I honestly dont think thats true, I think he was misinformed. Just wondering where the peak power is so I can tune the shift points for him. I did a 99 5.3L and set the shift points to 6200, I'm kinda leaning toward that for the 6.0 also. Thanks
Hummer
Old 11-10-2009, 10:08 AM
69LT1Bird's Avatar
I would say he is lucky if peak is at 5200-5500 range.
Old 11-10-2009, 10:15 AM
WS6HUMMER's Avatar
Yeah, its set @ 5200 stock. Thanks
Old 11-10-2009, 04:51 PM
formulaon18s's Avatar
Well if his stock truck cam peaks at 6800 you need to inform him you want to shift around 300 rpm after peak, so talk him into 7100 and get an in truck video of the test runs. lol.
I'm not full skilled in this dept, but if its fairly stock engine and stock is 5200rpm shifts I would move it up 300-500rpm but no higher.
Old 11-10-2009, 04:53 PM
WS6HUMMER's Avatar
Yeah I agree with you on that one.
Old 11-10-2009, 06:53 PM
SweetS10V8's Avatar
The LQ9 cam is 196/207 .479/.467 116-1. JUst by specs alone you can tell it doesnt need RPM. I ran it for a while and it was peaking at 5500 RPM(ish).
Old 11-10-2009, 07:00 PM
GMCtrk's Avatar
It peaks at 5200 rpm and is completely done by 5800 rpm.
Old 11-10-2009, 08:36 PM
Paul57's Avatar
I believe the truck motors (LQ9 etc) generally peak much sooner in the power band than car motors (LS1 etc) for towing/hauling.
Old 11-11-2009, 07:56 AM
WS6HUMMER's Avatar
Thanks for the info guys.
Quick Reply: LQ9 Cam info neded for shift points.
