Moser 12bolt vs Strange 12bolt
Like the title says which one should I go with? The Strange seems to be the cheaper of the 2. I will be doing a full spool with 3.73s if that makes a difference.
Both are great-except most people and shops do not properly install the moser. I have the Moser and havnt had any problems for the past 4-5 yrs I have owned it. If strange is cheaper and your going with a spool. Get the strange.
Like I said-moser rears are plenty strong-2 bolts or 4-dont matter. Its a bad install that makes the bolts come loose. and there is no aftermarket Tq arms drilled for a moser. Get the strange since its cheaper. And it takes less fabrication to install.
Umm, I think your wrong there. The Moser works with the stock torque arm, so any torque arm will fit, its just the bolt issue and them working loose with aftermarket torque arms.
Okay? I didnt say anything about a stock TQ arm. But thanks for any clarification. I know it works with a stock one too. Just saying the breakage Is from metal fatiuge due to not being secured properly. I did have a problem with bolts working loose. So when I was inpecting the install I noticed why. So I fabbed up bushings to cure the problem.
