Should I bend my spindle back straight?
Old 11-10-2009, 05:59 PM
Maxx's Avatar
Default Should I bend my spindle back straight?
I hit a curb on my front drivers side. Busted the steering rack and replaced it. Took it for an alignment and they cannot get anything better than +1.5deg camber. I took apart both sides and the left spindle is bent about 2". My friends suggest bending it back insteady of buying a used one from a junk yard that might be bent, too. I can probably have it done at the machine shop at my work.
Any comments or advice?
Old 11-10-2009, 06:09 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I would recommend replacing it.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 11-10-2009, 06:10 PM
samson_420's Avatar
I say get a replacement. . . . Yeah, it sucks. . . But, I don't know how you can bend it back to original.
Old 11-10-2009, 06:27 PM
hiltsy855's Avatar
I'm not sure if the spindles are forged or cast. If it's forged you might get away with it, if it cast forget it. Best bet is to get one from a bone yard.
Old 11-11-2009, 06:50 AM
Save the manuals!
wssix99's Avatar
You should get a new one. Bending it back will weaken it. If you bend a paper clip back and forth, you'll get the same effect. (The paper clip gets weaker and weaker each time you bend it.)
Old 11-11-2009, 09:17 AM
tuffluck's Avatar
definitely replace. you can take your old one to the junk yard, and/or call around the junk yards and find a junk yard that has multiple spindles. you can line them all up on a table and see which are the least bent if any of them are. if you use your current bent spindle for comparison, it should be relatively easy to find a good one. the v6 f-body uses the same spindle, so any spindle that works is the same spindle you bent.
in dallas i have found spindles ranging in the price of $30 to $150 for a used one. gmpartsdirect lists a new one at $200, so if you can't find a used one less than $100, just buy a new one.
Old 11-11-2009, 09:49 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Have to agree with everyone else. You need to replace it.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-11-2009, 02:01 PM
DONAIMIAN's Avatar
I would just buy new. Our stock spindles are pretty weak and I wouldn't waste my time with a junk yard.
Quick Reply: Should I bend my spindle back straight?
