hard starting after long tubes and true dual
Old 11-10-2009, 06:51 PM
cabotgsxr's Avatar
Default hard starting after long tubes and true dual
I just finished installing my new TSP 1" 7/8 long tubes and TSP true dual exhaust on sunday. i also change the plugs and wires out. now evertime i go to start it when its cold i have to crank it for like 10 seconds. before if would fire on the first hit. What could have happened?
thanks chris
Old 11-11-2009, 02:43 AM
uLs1a's Avatar
I would check your plugs and wires. I just did the same install but with 1 3/4" Hooker LTs and I also changed my plugs
Old 11-11-2009, 07:38 AM
cabotgsxr's Avatar
i put brand new plugs and msd wires on it
Old 11-11-2009, 11:12 AM
Frost's Avatar
right, and they are the most likely culprit because of that.
Old 11-11-2009, 04:41 PM
cabotgsxr's Avatar
it is also throwing a camshaft position sensor low voltage input code.
Old 11-11-2009, 06:05 PM
uLs1a's Avatar
Check the connection between the plugs and wires. Did you remove the starter when you put the headers in?
Old 11-11-2009, 07:44 PM
intense3123's Avatar
Without the cam sensor working properly, the PCM won't know what position the engine is at to send fuel. It will have to check the crank sensor to determine position and that'll take longer to start since it has twice the possibilities.
Old 11-14-2009, 09:06 AM
350 WS6's Avatar
check all the censors and emissions.
